CS for multiroom using cccam on DM800
JeB
Dreambox DM800
Jersey
Hi Guys,
Hope you can help me here!
I have a DM800 using my Sky card (using boxkey etc..) all works fine.
I also have a clone dm500 that I would like to cs. I am using CCcam 2.14 on both boxes and have the following lines in cccam.cfg on the boxes....
(on the DM800) F: user pass 3 0 0 {0:0:2}
(on the DM500) C: 192.168.1.11 12000 user pass no
Both boxes can see each other but the dm500 will only get FTA...Any ideas why?
Hi there, put spaces after and before the {} like this.
(on the DM800) F: user pass 3 0 0 { 0:0:2 }
Have a look at _http://192.168.1.11:16001
See if it shows the 500 connected as a client.
Thanks B16MCC... tried it and worked a treat! As I am this far, might I ask a couple more questions?
I take it the Dreambox will always look for a local card before it goes to cccam.cfg?
Could you have more than 1 C line for different shares? if so would it try the first line, then go to the second etc until it gets a key returned?
Many thanks!
Cheers,
JeB
Yes that's the theory and yes again, you can have multiple F and C lines. As a general recommendation when using a Dreambox to host your card I would stick below 12 or so shares. Of those 12 if you get more than half active on your card, you'll start to see problems. Simply a traffic limitation on the box and the card.
