all H to H motors should have a range of 90 degree,s either side of zero really and should be set to maximum at the factory but it doesnt seem to be the case... its then left to the installer/owner to either use the mechanical/software limits or both dependent on the reception site.
2011 diseqc motor
DG-240 dish motor ,special designed for receiver with DiSEqC 1.2,Diseqc 1.3(USALS).Ultra Low Noise.New Struct
2011 diseqc motor
DT240 dish motor ,Special Design for Receiver with DiSEqC 1.2,Diseqc 1.3(USALS)
Only One Coaxial Cable Control
Go To X Function
High Efficiency
New Compact Structure
Ultra Low Noise
Adjustable Hardware Limits
Easy Installation with LED Indicator
Manual EAST / WEST button
For Dish up to 1.2-1.4M
Specification:
Model
G240
Antenna Diameter: 1.2-1.4M Max.
Length of Motor Tube: 18cm
Azimuth Angle: 80 degree EAST ~ 80 degree WEST (160 degree) Adjustable
Elevation Angle :25 degree~75 degree
Input / Output Voltage: 13 / 18 VDC
Power Consumption :50mA ( Standby mode ) ;200mA ( Normal) ;350mA ( Max.)
Rotation Speed: 1.9 degree/ sec (at 13V) ; 2.5 degree/sec (at 18V)
Satellite Positions: 60
Connector: F Type
Command Protocol: DiSEqC 1.2 ,USALS
Resynchronize Function: YES
Goto Position 0 Function: YES
Goto X Function
ES
Positioning Sensor: Hall Effect Sensor
EAST / WEST Limit: Adjustable Hardware and Programmable Software
Manual Button: EAST / WEST
darkmotors are just badged... as an example if
@Analoguesat were to go to a supplier on alibaba and say i want 10000 usals motors they would call it whatever he liked... im a stab fan myself but for the price the darkmotors are gvfm and are better made than some that are out there.. the TM 2300 as an example its rustproofing on the bracketery is shocking.
