BGonaSTICK said:I've found that both on startup and shutdown, the motor will attempt to drive to an unspecified but constant 'default' sat location, but only when I had mangled one of my images a bit (by manually fiddling), and the box wasn't starting up or shuting down correctly.
Not a lot of use I know, but some emu re-installs may help, or an auto-rebuild (via the autosat plugin) of your satellites.xml file if you have one installed.
STICK
