desperate for a solution
nicdan
laptop and sat receiver in a LAN
greece
hi
i have being trying hard for over a month to get my gamma plus card working with my dreambox.can someone suggest to me the right settings so the box sees the gamma.the system i have is the following:
dreambox:600pvr genuine
external reader/programmer:cas3 interface plus/phoenix
image on greambox:gemini with cccam 2.1.2 and newcs1.67
any help (how to set up cccam and/or newcs) will be greatly appreciated.if you think i should change the cccam and newcs versions pls tell me so with the required changes for the software of the suggested versions
Did you check in internal dm600 reader?
It's an easier solution, better to configure that for an external programmer.
Max
