Diablo Cam - Advice please on Underworld and Stealth?
jasperham03
Topfield TF7710 HD PVR with motorised 1m dish. Diablo Cam
Hi Guys,
Still a little new to this and do not understand the difference between the underworld file and the Stealth file? Do I need to download both onto the Diablo? If so any particular order? When I have downloaded the underworld file and then download the stealth file it seems to overwrite the underworld file - any advice appreciated.
Shaun
Stealth files are the very old software the new software files are Underworld so just load the latest Underworld file which currently is Underworld 163.
You might want to also load the latest Diablo keys bin file.
Great, Thanks for clearing that up Mickha. What do the bin files actually do? If I just download the latest Underworld file will that not unscramble everything, or will I get more with the bin files? If so where do the bin files get loaded to on the cam?
Shaun
