Diablo CAM WiFi card running Underworld 2.15 detects Nagra3??
wribeiro
Notebook Toshiba Satellite M65-S9092
Zinwell ZDX-640 CI in StarOne C2
Diablo CAM WiFi
Brasil
I inserted an original Nagra3 card in my Diablo CAM WiFi running firmware Underworld 2.15 and it detected the card, identifying the Coding System: Nagravision 3 and ATR, with a sequence of 27 hex pairs.
However, when I try to tune to any encrypted channel, the CAM gives the following message: "You Have the rights to watch this program". As the card is paired with the receiver provided by the operator, I suspect that the error has something to do with it. Has anyone done testing to insert a card in Nagra3 Diablo CAM and obtained a similar error message? Can we have the expectation of the Diablo WiFi card work with Nagra3? Are there any suggestions about what can I do?:confused:
You would need the original boxkey information from the paired receiver to get beyond this point, and unless you have a degree in computer science & the added hardware/software to extract the info from the original receiver you can forget getting the card to work. D+ (Spanish wing of Canal Digital) do the same with their end user receivers & cards (Also Nagra 3).
I have the original boxkey, how can I search this information in your menu? There are these: Receiver info, SW, Driver, Core, NP and Guide Version. What do I need?
