Digisat pro Help
warrior121
Likes
south wales
#1
Please can anyone help me ? I have got a digisat pro sat meter and it works perfectly fine on Astra 28.2 E, Astra 19e and Hotbird but on other satellites i cant get it to show any signal . Say i move my dish to Hispasat then plug it in there is no signal but if i move the dish to Astra it shows a full signal .
Is there something i can do about it ?
Thanks.:)
Likes
1,279
#2
If there is signal there, it'll show it, how do you know that you are pointing at 30W?
Topper
Amo Amas Amant Admin
Likes
3,243
IDD CI24 ECONO MM Penta 1.20 Galaxy II
1.2Mtr Polar MTG yes it has been on the arc for 25 years and is now fixed on 13 East using two pairs of rusty molegrips. Unlike me they never groan but always perform.
Blackburn, Lancashire
#3
You may be able to find help here there are some threads on the forum but I'll leave you to decide if they are useful
warrior121
Likes
south wales
#4
What i mean is when the dish is at 30w my reciever shows about 80% signal and i can watch everything . But when i connect the meter it shows 0% signal .:confused
Likes
Pace 2200 Sky digibox with ftv card, Comag SL65 FTA sat receiver, 40cm Sky minidish, Setpal terrestrial receiver (for free uk tv only!).
Midlands
#5
Sure you've switched to the correct lnb input?
I've got a digisat, cheaper single input lnb model. It started regularly failing, and on opening up case I discovered the lnb socket had never been soldered to the circuit board!
However, that can't be the problem here.
