Digisat Pro...
Cargosat
None
Manchester
Does anybody know if the Digisat Pro meter displays sat info? Or am i i best forking out for a Lacuna meter or similar?
Cheers.
wod
yorkshire
no it doesn't tell you what satellite you have aligned to, only just a signal strengh bar on an lcd screen
for anything like satellite NIT readout you will need a meter like the satlook micro, horizon hdsm v3 or wolsey/lacuna meter
gunn1e
Sky-HD
S.E. United Kingdom
Mine does, for example if i am pointed at 5.0e the display says "KRRT 4.8E" I have a pro 204
Can't find that model on the emitor site, have you got the spec?
BombedOne
Republic of Georgia
Mine also does not. And btw, it's not a good investment I believe. Does same, as cheap finder.
gunn1e
Sky-HD
S.E. United Kingdom
This is mine, _http://www.swires.com/pdf/digisat204ds.pdf
don coolman
dream5000
v box
1metre motorised
n w england
Try the Satcatcher exel TV. Its got all the European channels in it, got a speccy, and will show picture and sound on the FTA channels. It also drives a diseqc motor! Comes with a handbook in english - well Yorkshire English actually - and a CD to write or edit the channel plans. We use them for all our work, including motorised.
OK, thanks, but that isn't the Digisat Pro the original poster was talking about, yours is a Swires meter and probably quite a bit more expensive.
Yes, it is a nice little meter, have seen them in action and was very impressed, but we are talking about a meter which costs in the region of £50, not £250. :)
don coolman
dream5000
v box
1metre motorised
n w england
Hi Rolfw,
Yes its about £445.00+VAT
patmos
STRONG SRT-4910+,SunRay4HDse,TBS5922, 2.4M P.F Apstar7(76.5 DEGE), 120cm dish PAS 10 Ku( 68.5 DEGE),3.0M Mesh Motorised dish on arc (AM44 (11DEGW) to AM33(96.5 DEGE),150 cm dish W3C(16 DeG E)+ side LNB Ew2A(10 DEGE),90cm W4/W7 (36 DEGE)
Mauritius
don coolman. why is must be the 22khz ON for KU universal LNB to work on this meter. Is this normal? For C band no 22KHz is needed.
C-Band LNBs are single band, whereas a Universal LNB is dual band and uses a 22Khz tone to switch to high band.
patmos
Mauritius
Thanks I understand now. Higher frequencies (LO 10600) needs that band switching.
