Hi, does somebody know the exact length of those three feed arms of a CM 2.4m ? I got an old reflector with the feed arms missing... I'd like to make them myself. Thanks.
Measure your mirror precisely, enter data to program (for example Parabola4) and that will give you all needed dimensions for LNB position.Hi, does somebody know the exact length of those three feed arms of a CM 2.4m ? I got an old reflector with the feed arms missing... I'd like to make them myself. Thanks.
Hi, if I dont forget I will measure my dish this evening. Or if I do forget you can drop by and diy it.I tried to find the position of the LNB using the programmes, however it seems impossible to measure the exact depth and deepest point of such a big dish... it would be really nice if someone with a 2.4 CM could measure how long those feed arms are...
Hi Pietlock,I tried to find the position of the LNB using the programmes, however it seems impossible to measure the exact depth and deepest point of such a big dish... it would be really nice if someone with a 2.4 CM could measure how long those feed arms are...
Thanks/Danke you for your help. Seems like you have the professional variant, which can also carry a Tx/Rx device. The reflector is the same however. I have the semi-prof variant with the simple LNB support only ( I have the feed, just the arms are missing ). Got this thing "3rd" hand.... so measuring the exact position of the feed horn is better, so a visit is probably not a bad idea.
Yupp, thats mine. But as you said, the reflector seems to be the same. Mine has the notches for the other feed assembly.This is yours I think : http://www.satellites.co.uk/forums/attachments/img_0255-jpg.32613/
mine looks like this _http://www.skysat-ibiza.com/images/home/24ravenescubells.jpg
