diseqc 1.0 und 1.2 what is the difference
W
westsider
Likes
is it possible ?i want to use diseqc 1.0 with 1.2 motor.what is the difference? must i update the software?will it work?
I
IjonT
Likes
Opentel 3500 FL, LNB 0.6 dB, 60 cm Fe
#2
Only a switch can be controlled with DiSEqC 1.0, not a motor (as far as I know). You need DiSEqC 1.2 for a motor.
But if your receiver has some menu items for motor setup then it has probably DiSEqC 1.2 anyway. Why not try it and see, what happens?
gameboy
gameboy
Ding Dang Doo
Likes
5
Scotland
#3
More about it - Designed by Eutelsat you can find all the information here...
_http://www.eutelsat.com/satellites/4_5_5.html
W
westsider
Likes
my receiver has built-in positioner with east-west funktion but i am not sure.i make it first times.i have instaled 1 meter dish and now i have bought sat motor with diseqc 1.2 my receiver seems to have 1.0 while i have it in its official site read.that without update it has 1.0 but it has 2000 year status and i have not updated it.
gameboy
gameboy
Ding Dang Doo
Likes
5
Scotland
#5
Did you check the Eutelsat site link above?
I
IjonT
Likes
#6
westsider said:
my receiver has built-in positioner ... without update it has 1.0 but it has 2000 year status and i have not updated it.
Built-in positioner has nothing to do with DiSEqC. You need to update your receiver to DiSEqC 1.2 if it is possible.
