DiSEqc 1.2 motorised H-H motor
pherbert
fortec
oxford
Hi all, I have a DiSEqc 1.2 Motor, it makes no mention of USALS ?
I am using a comag sl100HD receiver and its been great, but I am not sure that the motor is compatable with USALS, can anyone advise.
The box has the USALS feature, but I find that the dish says its on a cirtain Bird, but is the wrong bird. I started at 0.8 Thor, and found 28.2 ok but it gets confused in between.
thanks for any advice
What motor is it?
Or if not sure, you can always post a picture of the motor.
Sent from my BlackBerry 9700 using Tapatalk
USALS can also be called 'GOTO-X' on some systems.
Why not stick with the DiSEqC 1.2 settings and ignore the USALS stuff completely ?
