satkingno
- Vu+ Duo2, Vu+ Solo2, Vu+ SoloSE, Wavefrontier T90 1W-5E-9E-10E-13E-16E-19E-23.5E, Channel Master 1.2m 28.2E 4xEMP Centauri 9/1, 8x Inverto Black Ultra Quad
- Norway
Hi!
I have searched the boards, but there does not seem to be a definitive answer for this.
What is best for fringe reception, a regular quad/diseqc setup, or quattro/multiswitch? I have heard that you are supposed to increase the dish size a little when using mulitswitches, but is there really any truth to this?
The diseqc switches I currently use has an insertion loss of typically 5db:
http://www.emp-centauri.cz/index.php?lang=en&page=prodview&id_kateg=1&id_pkateg=21&id=82
The Multiswitch I am looking at has a loss of 3 db:
http://www.emp-centauri.cz/index.php?lang=en&page=prodview&id_kateg=1&id_pkateg=15&id=75
In addition to this, the internal switch in the quad LNB is removed, so shouldn't it be even more loss reduction? Does anyone have experience with changing over from a "normal" setup to a multiswitch setup?
Regards
Tommy
Regards
Tommy
