L
lmarconi
- 2 Dish, 13 and 36 east
- Kazakhstan
Dear all, is the first time that i wrote in this forum and sorry if what i wrote will be not understable or stupid for you that, for sure ,are much more expert then me. I would like to explain my problem.
I'm locate in KAzakhstan for work reason and, actually i have 2 dish : first dish on 36 east Eutelsat (with a LNB with 2 entrance) and second dish on 13 east (Hotbird) with an LNB with 4 entrance. Since in my apartment i have to receiver (DREAMBOX D500S) in 2 different room, i bring from the roof (where are located the dishes) 2 different and indipendent cables, one for each receiver .
Each receiver should have the possibility to use the 2 satellite, so i use (for each cable) 2 different DiseqC with 5 entrance (4 plus 1 for the receiver). So for each DREAMBOX i have the same configuration: one satellite (36 east) to the entrance of Diseqc (AA), one satellite (13 east) to the enstrance of Diseqc (A
and from the DiseqC to the room. As you can understand are exactly 2 different cables connected in the same way.
Now, with the hope that i have been clear, the problem : if i switch-on both the DREAMBOX , i can't use one to watch 36 east and one to use 13 east. It is look like the 2 are connected since as soon as i switch on 36 east in one DB, the other which is setted on 13, stop to work saiyng Service not find. The only thing that i can do to have good signal and channles is to switch both DB on the same satellite.
Second problem : this happen in only 1 DREAMBOX: if i switch on only 1 DREAMBOX (the second is off), some channels are not showed and appear the same message (Service not find) and the satellite signal it is very low. Only when i switch on the second DREAMBOX, then the channels appear again and the satellite signal became full as usual.
Sorry, i know that it is a long message but i try to explain as much as better and i hope some of you can help me on this strange problem.
It is a DiseqC problem ? If not, what it can depend the behaviour of the receiver which should be completelly indipendent while look like are connect in some why ? It can depend from the LNB ?
Thanks in advance for any support which any of you can give me.
Leonardo
Leonardo
