CSB
- Max-Digital XP1000 & DM500 that just keeps going (7 years)
1m TM for 28.2e, 23.5e, 19e & 13e. 60cm for 30w
- London
Can anyone advise me on the best location for fixing diseqc switches(2) on, or near my 1m dish.
I'm unsure wether they can be mounted on the LNB arm close to the LNB's or should be mounted behind the dish....or.... further away. Also are there any issues with the 2 switches being close together ?
" The switch cover has a molding that is the same profile as the LNB arm, with cable tie holes"
Switches are Technomate TM4S
Thanks in advance csb
