Dish Alignment problem
skidvik
SKY
Devon
Is anybody able to recommend someone in the Exeter area that will be able to re-align my dish set up. I managed to do something whilst trying to remove a tree blocking the dish.
Since you haven't had a reply yet, maybe you could have a go yourself if you can have access to the dish. If you can remove a *tree*, alligning a dish should be easy. Buy yourself a simple sat meter (about 10 pounds) and attach it to the dish ( you will need a few feet of cable with a sat connector either end) and then slowly adjust the dish until signal maximizes.
well come on please do tell what you did
