Evenfull afternoon today......Decided to dig out of storage my old Pace positioner for one last try to get the dish moving.......Last time tried would not move dish........
Wired it crude 4 wires stuck into rear of unit......Hey presto the dish moved.....To what position no idea as I had then lost my channels on 13deg. So i thought why not try the stored position for Astra 1.....Dish moved again so I set my reciever on scan but no signal was present even though it scanned.......No channels found.......
Messing about with the Pace positioner remote I played with east/west bottons while still scanning 19deg hey presto I got a signal......Did a rescan and found over 500 channels but the picture was breaking up. Inched the dish a little further east. At last now I have over 700 channels and picture normal. About 8 frequencies however would not give a signal.
Just settled down to nose through the channels and the phone rang.....It was an installer telling me ho could come this afternoon to give me an assessment. Fine I said.....
He arrives and does some work on the positioner settings and he said dish moving fine.......He takes a look at the set up outside and say's I don't need to change the dish. LNB is working fine motor working fine. I'll set up and store the positions on the Pace.....
Which he did. He said if I were you use unti it goes wrong. In the mean time with a new reciever you can get an adaptor to change the voltage to 36v between new reciever and the reed motor you have.
He must have been with me a couple of hours and just as we were about to to a final check on the work he had done storing the dish positions.......Disaster struck. My Samsung receiver just clapped out no power for more than a couple seconds.....
The only test on my equipment he could do then was to move the dish to Freesat.........Which it did ok. Have been testing on the TV and the dish is moving and returning back to Freesat ok...
But I am now receiverless........Ah well you can't have everything..
He seemed an honest bloke he did not try to sell me anything I don't need.......
Probably will eventually discard the positioner and have a modern setup
