OldBen
Mad Scientist
- Triax TD110 with multi LNB 28.5E, 23.5E, 19E, 13E Inverto Black Ultra's (Black Premium on 28.5) into multiswitch.
- UK
Hi All,
So helping a friend last night (mainly as ladder ballast) change his old motorised dish that came with his house to non-motorised with a quattro rather than dual LNB.
The house had a 36v motor and a clear dish, it looks about 85cm but I don't think its a Metronic like mine as the construction is totally different (unless its just a lot older model, when they bought the house it turned out the dish had planning so pre 2005it seems!).
Why remove the motor I hear you cry? Well its 36v, its parked in the wrong place, he has nothing to drive it around to 28.2, and nothing to use it later so easiest seemed to be to remove it. Clearly removing the motor required setting new inclination on the dish (and yes pole is dead vertical, checked first).
The problem is setting the inclination (I think he needed 25degrees) that the full scale is on one part of the bracket as expected, but rather than a central marking on the other part of the dish bracket there are three?!
They have markings something like:
85-105
85
65-85
Which one should be used to set the 25 degrees inclination? (are they latitude ranges?!)
Any pointers appreciated, slight shortage of compression F-plug tools yesterday so lots cabling but no alignment, clearly some trial and error could be used but would be easier for this to just be in one axis finding 28.2 rather than two axis with the inclination as well!
Paul
85-105
85
65-85
Paul
