Dish Installation on Wooden Post?
cia.kelly
Dish: ASC Signal "Channel Master" 120 cm.
LNB: Invacom QDF-031 with Channel Master feed horn.
Box: Humax Foxsat-HD
Stockholm
Hi All
I am surveying possible sites at my home for my Channel Master 1.2 dish.
The Dish needs to go the front of the house and I'm wondering if I could set it up in my garden, attached to a wooden garden post.
I am thinking about a 6X6 pressure treated garden post cemented into the ground.
Almost all the installations I have looked have used a metal pole. Is using a wooden post a big "No No"?
nelson_b
Contributor
hi -
i,v tried this -- it was solid enough in the vertical --although the post was kept quite short
but in the wind the dish wobbled form side to side quite a bit due to a sort of twisting/flexing action of the wood --
if its in a exposed place it could give stability problems --
sheltered it might be ok
a strong metal tube is much better
regards nelson.b.
Chris76
Vu+ duo with a 300gb hdd also dm500 and tecnomate 5200 with a 1m and 1.1m motorized dishes and minidish fixed to 28.2
Belfast
I would recommend a galvanized 2" steel pole and they are reasonably priced and very stable.Just take time getting which ever you use getting it perfectly plumb.
Robbo
Retired Mod
www.mbcsatellites.co.uk
Gravesend,Kent,UK
Its a bit of a waste of time using a wooden post in my opinion, as the most time consuming part of the job is digging the hole. You'd be saving a little bit of money on the pole and that's it.
Plus you'll have to devise a way of fixing the dish to it, as it needs to be attached to a metal pole, so that you can adjust the azimuth.
At least a 3 inch diameter pole would be ideal.
Ive used wooden posts for years:
http://www.satellites.co.uk/forums/...farm-renovations-new-1m-dish-added-setup.html
Ive gone up to 1m Orbitals on them (1 steel, 1 aluminium)
I had no end of problems with the older and heavy steel dish - the post kept moving in the winter storms. Eventually I found a long steel pole, slipped it through the loose u bolts and belted it into the ground with a sledgehammer to take some of the weight. Then tightened the u bolts up properly :D
Its been fine since. :D
BTW none of my posts are concreted in - they are just knocked in with the sledgehammer. A complete bodge job, but it works ok most of the time as my garden is reasonably sheltered.. I started these sorts of dish mounts off about 4-5 years ago and they have been fine.
FWIW personally I dont think Id try this with anything heavier than a 1m steel orbital dish.
Sandybob
1.2 Channel Master and polar mount, 1.2 Gibertini, 1m Orbital, SG2100A, tm-5400, tm-600 linux, manhattan xt-cm, v-box III, and lots of other stuff in the attic!
uk
The channel master 1.2 and mount is a very heavy setup and really needs a 3" steel pole to fit the az/el mount or polar mount as they both fit on the top of the pole, if using a jaeger 1224 motor you may be able to get away with a slightly smaller pole, but I think it would still have to be steel. You could make a 3" ground stand and bolt it to some very heavy pavement slabs or kerb stones if it was in a sheltered location. Easiest method is a steel pole in concrete.
headman
1.2 dish and hoping to get a motor installled on it
Ireland
what about a tree
lol
cia.kelly
Stockholm
After talking to "The Government" it has now been decided that she doesn't want it in the garden and it is now to go on the side of the house :confused
