dishpointer pro for android???
iwol
channel master 1.2m dish
technomate 6900,,and invacom 0.3 quad lnb
satlook micro
yorkshire
hi just ordered an android phone and just wondered where i could get the dishpointer pro app for this android,and do you have to download it on the phone itself thanks guys
_http://www.androidzoom.com/android_applications/productivity/dishpointer-pro_blgo.html has it.
thanks rolfw,have you tried it and do you have to download it via the phone or pc or any
Nope, haven't tried it I'm afraid, as I don't have an Android or iPhone, but those on here who have tried it with the iPhone find it useful.
I think you probably download straight to your phone.
G'Day, on the Android link it through your computer via wireless, then go to "market" and you can download it from there. Also of use is GPS Test from Chartcross as it has a digital compass and other little bits that will help.
Makes life very easy to see where you might have to put a dish.
thanks brisat actually did it through the market icon on the phone itself sure is a good app
Just how accurate is the gps in these phones? If it is inaccurate then the app might give suspect results.
If they are accurate then I would certainly consider getting an Android phone, as this could save a lot of time on some installs.
If not then the money might be better spent toward a new meter or even toward some better ladders!
im happy with mine but then again im not a pro installer,i used mine on a tmobile pulse,really is an amazing phone
