Ghostleader
- May 23, 2009
- Age
- 46
- 80cm motorised Inverto dish with Dark Motor full metal gears, Xtrend 9500HD, Amiko Alien 2+, Amiko Alien 8900, Moded Zone 2 dish with multi LNB goodness! 50 inch full HD LCD and loads of other stuff! lol
- Glasgow,ish!
Ask your average Sat enthusiast how to set up a multi LNB bracket on a typical size dish etc and they will tell you if it's for the usual three birds (13e,19e & 28e) then you should focus the main LNB on 19e & have 13e at one side & 28e at the other, which is sound thinking & works very well:-thumb1 . However my gripe is with these people who shoot down any other thinking/configuration in regards to LNB placement, if you suggest to your average serial poster/bullsh*ter that you were considering using 13e as your focal LNB & 19e & 28e as your offset's they will tell you it wont work unless your dish is a metre, it wont work at all, or at the very thought of rain 28e will break up like indoor aerial having a go at Freeview while someone in the room decides to test four hair dryers right next to it. Well to those in the know:-uzi, say hello to my little friend:
