dm-800 hd help
sut
sky plus box
birmingham
is this box any good as its a chinese version, but does seem really cheap. also on aside note i see you have a dm800 and an 8000 section are these 2 different boxes.??
DM800 FTA Satellite Receiver HDTv Chinese Version
£280.00
- 300 MHz MIPS Processor
- Linux operating system
- MPEG2 & 4 / H.264 Hardware decoding (DVB-S/S2 compliant)
- DVI
- DVB-S Tuner Module, Plug & Play
- Common available NIMs (DVB-S, DVB-C, DVB-T)
- High contrast and energy saving display (OLED)
- 64 MByte Flash, 256 MByte RAM
- SATA connection for use either as internal HDD 2,5“ or eSATA
- 10/100Mbit Ethernet Interface
- 1 x smartcard reader (Dreamcrypt)
- 2 x USB2.0
- V.24/RS232
- Scart socket
- S/PDIF for digital bit stream out (optical)
- Unlimited channel lists for TV/Radio
- Channel-change time < 1 second
- Supports EPG (Electronic Program Guide)
- Full automatic service scan
- Supports directly bouquet-lists
- Supports videotext decoding
- Supports multiple LNB-switching control (DiSEqC)
- OSD in many languages
- Skin-support
- External 12V power supply
The DM 800 PVR also has 1x smart card reader and I can asure you that it is a great box. The DM 8000 PVR is a much larger...much more expensive....and incorporates a dual Tuner system ( can in fact accomodate a total of four Tuners), 2x smart card readers, 4 DVB common interface slots, and W/Lan .
