dm500 help required
dearmoawiz
Dm500
Saudi Arabia
hi ..
I am new here in this forum and wid dreambox as well.. I want to update my dm500 with new image i connected it with my laptop using cross cable & CuteFtp and there in CuteFtp it showing me all files of dreambox.
Now My QUESTION is that how can i update with new image from where i can download new image and in which folder of dreambox i have to place that image, what will be the step for completing this task.
Thanks in advance...
Regards,
You should do that from the box, make sure it is a genuin box before You use any Gemini images
Thanks for ur response dig deep but how i do that from box wat will be the stepz for that .. i want to know n where i have to place that gemini image i mean in which folder please tell me this .. i want to know the steps for placing new gemini image and in which folder i have to place that image ..
will wait for your response ..
You do that from the blue panel, the box will install the new image automatically - You don´t have to do anything after download
If its a clone and you stick a Gemini image on it theres a very good chance you will trash the box.
(If the box is less than 2 years old its a clone) :D
hello. i have dream box 500 s for the last one and a half months it worked good and now only free air channels are coming and other channels have black screan with information coming of programe and time , and i am using dream box with card sharing. please help me with this .
thanx
Talk to your share operator. He is the only person who can help you.
If its a pay server then we cannot help you as discussions whatsoever of any pay servers is strictly forbidden here.
