This is a common problem. Best solution is to sort this out via your PC. To check that the box can see your HD, install DCC (Dream Control Centre) , and use Telnet to give the command "mount" or "fdisk", or "blkid". from the returning info, you can see if the HD exists. You do need to be able to interpret the Linux info. "fdisk" gives the clearest info.
