andyxxxx
- DreamBox DM800HD - Technomate TM600 - Technomate TM500 Super - SkyBox F5 -- Triax TD110 Dish on TM2600 Motor - Zone 1 sky dish
- Newcastle, UK
I've just recently started using my DM800HD again and the remote is very worn, lots of the keys are worn and you have to press some very firmly to get them to function.
I want a replacement but my current is a clone and does not include the functionality to control the TV (I remember reading somewhere that some of the clone remotes, especially earlier ones, didn't have this functionality programmed so would never work). I've tried with several TVs and none have worked so just assumed this was the case for mine.
Can anyone recommend somewhere to get a replacement that will also control the TV? There's some cheap ones on eBay but i'm not sure if they will do what I want.
