dreambox 500 hd help
jpsr
1.2 channel master, cm polar mount, 12 inch actuator, Andrews feedhorn, Inverto lnb, Superjack positioner, Dreambox dm 500s, Protek 9600ip, 1m channel master with black ultra & 1m gibertini with technomate twin output lnb on astra 1/2, TM 5200 & 1000
Mullingar, Ireland
I got a dreambox 500 hd clone with peter pan neverland image installed.
I cant seem to find my satellite list, it shows astra 19.2e, but no way of selecting any other sat, or ways of using a motor.
I went through every menu and cant seem to find any sort of satellite configuration, completely different to my dm 500s.
I would Install another image, for a newer one with a more upto date satellite list.
Just make sure you get the right image to suit what ever sim card is in the receiver.
It will probably be a Ferrari sim that's in it as its one of the more common ones in the DM500HD clone.
The PeterPan image is not the best in all honesty.
Nano
Thanks for that, i will have a look for a new image.
Is the open pli image any good for the hd box.
