Dreambox 7000s & Redlight won't work for me
longstockings
Satellite Whore
Likes
Technomate 1500 CI+
80cm Polycarbnate Dish
0.3db Universal LNB
Moteck Digipower Motor
Totnes, Devon 50.4320N, 3.6690W
#1
I ordered a Redlight 5 in 1 card from QCleisure but can't get it to decode any of the 5 channels.
I saw a tutorial on Satdudez to get this working and edited my cardserv.cfg as told.
I used ultraedit to edit the file
It now looks like this
DESKEY = 01 02 03 04 05 06 07 08 09 10 11 12 13 14
SERVER_NAME = cardserv
DEBUG_PORT = 14000
ENTITLEMENT_PORT = 14001
ADMIN_PORT = 14002
ADMIN_PASSWORD = secret 00 00 00 00 00 00 00 00 00 00 00 00 00 00
USER = local local lan dreambox 12000 au
DEBUG_INIT = no
DEBUG_NET = no
DEBUG_ECM = no
DEBUG_EMM = no
SERIAL_PORT = 0
TCP_PORT = 10001
EMM-G = yes
EMM-S = yes
EMM-U = yes
SPECIAL_FEATURES = yes
DISABLE_PIN = yes
SERIAL_PORT = 1
TCP_PORT = 10000
EMM-G = yes
EMM-S = yes
EMM-U = yes
DISABLE_PIN = yes
#SERIAL_PORT = 2
#TCP_PORT = 10002
#EMM-G = yes
#EMM-S = yes
#EMM-U = yes
#SPECIAL_FEATURES = yes
DISABLE_PIN = yes
I must be missing something
I want to use Newcamd 5.25 (hydra zeus) and have set newcamd as the default softcam.
If anyone has this working could they please spend a minute to help me out.
sonic1
Likes
101
Vu + Ultimo 4K - Solo 4K - Uno 4K - Duo2- SoloSE - Zero- Uno -Prismcube Open Black Hole - 0.6 , 98cm Funkee , 28E-23.5E-19E-13E
Black Hole Team
#2
Have same set up and using scam as newcamd 5.25 does not work.
Hope this helps!!!!
longstockings
Satellite Whore
Likes
Technomate 1500 CI+
0.3db Universal LNB
#3
What exactly is the procedure for activating a card using scam ?
If I go to Common Interface under expert setup it tells me that it has found a module but if I click it it tries to get a response from the card but that doesn't seem to do anything.
I am using Hydra Zeus
Butterbox
Likes
Dreambox 7000s serving 4 500s. 2 fixed dishes + 1 motor.
Dragon 4.1
Mayo, Ireland
#4
Try this.
Assign Radegast as your main softcam. Hit "OK" on the remote to go into the Radegast setup. Using the left arrow pick the slot the card is in. Then select Radegast as the softcam for the channel and you can change back the main softcam to whatever you want.
longstockings
Satellite Whore
Likes
Technomate 1500 CI+
0.3db Universal LNB
#5
I have tried that before but I got a message saying that the settings can not be edited at this time or words to that effect.
This is when I press green when viewing a channel
Presumeably if I want to change the softcam settings I have to be on a fta channel and make sure the softcam is not in use.
I think I have answered my own question and can't believe just how thick I am being
touchingcloth
Likes
I think you've also answered my question.
Shame that I gave up on trying to edit a cam therefore reflashed as I thought it was a problem with my image!
Nayways...I'm way behind you guys...I ahven't even managed to decrypt a singel channel yet
longstockings
Satellite Whore
Likes
Technomate 1500 CI+
0.3db Universal LNB
#7
I can't edit newcamd the thing won't let me.
I can edit Radegast and Scam but not Newcamd
There must be a reason for this but I'm buggered if I know what it is.
How long should it take b4 they clear ?
I enabled the top slot and everything but still black
I went to a free to air channel and played with all the softcams but no joy.
I assumed that if Newcamd 5.25 had nothing to do that I would be allowed to edit it.
Can anyone shed any light on this.
And why does this editor always do weird spacing when I type using Firefox.
sonic1
Likes
101
Black Hole Team
#8
Hi longstockings!!!
Ok press blue button, Default softcam, I have Newcamd v5.25,
Then on say Free-x softcam select SCAM (25/11), Then do this for all
the channels Freex 1&2 x-dream and both redlight channels.
No need to do anything else.
Just make sure card has chip facing down.
Card should clear within minutes.
longstockings
Satellite Whore
Likes
Technomate 1500 CI+
0.3db Universal LNB
#9
Newcamd 5.25 is working with the Redlight card and the channels are clearing all be it rather slowly but I'm not moaning.
Well not as much as some of the actresses I just saw anyway
Thanks again Sonic1
