Dreambox 800HD eletrical problem?
andraro
Dreambox 800HD
belgium
Hello,
I have a Dreambox 800HD and yesterday I switched on the TV and I had a green screen, nothing written on, couldn't do anything, not even switching it off. So I had to remove the power manually. After restoring the power, the Dreambox don't how the main front screen.
No power arriving? is it possible that the answer is yes even if the Ethernet cable turns on the lights and it seams that the box makes a buzzing noise.
Hoping I haven't burnt an important peace.
Thanks for the help
Problem solved by keeping the power cable disconnected for a hole day. I guess I just over heated it
