Dreambox help
Likes
Dreambox 500s
Greece
#1
I have found keys all over the internet but most of them are text in webpages or text files.How can I make them be recognised by my Dreambox 500s ???
mhku
Likes
20
TM Nano ~ sg2100
Midlands
#4
What image are you using? Which emu are you using (newcamd, camd, scam etc)?
Go to fookfiles and download the Spartan keys.
Unzip. Put the keys into var/scce or var/keys depending upon which emu you are using.
Also, look in the Idiot's Guide in this section.
Likes
Dreambox 500s
Greece
#5
I did it,but in the hotbird satellite,I can only see TPS,Polsat,ABsat and some eurosport channels.Is it possible to see the ARTs ??If yes,how ??
john_graydon
Likes
Dublin....Ireland
#6
No Not possible to see Art without card. If you can view Multivisions & TPS then you have the latest keys in.
mhku
Likes
20
TM Nano ~ sg2100
Midlands
#7
You're doing better than me ;) haven't got tps/ multivision....
tallguy74
Likes
db7020
3 LNB (ast1/ast2/hotb)
c+ NL
SDT Davinci
nl
#8
what image do you use, and which emu's do you have installed?
mhku
Likes
20
TM Nano ~ sg2100
Midlands
#9
It's because I've been on holiday and haven't got the latest keys (I guess). Using Gemini and newcamd 5.28
Spartan has just posted a new set so may try those tonight and hope tpscrypt works for me ;)
john_graydon
Likes
Dublin....Ireland
#10
Dont forget about 30w, Taq & C+ Open with camd3
mhku
Likes
20
TM Nano ~ sg2100
Midlands
#11
Cheers John, so am I better off using camd3 instead of newcamd?
Likes
Dreambox 500s
Greece
#12
Am I able to see any other bouquets with my dreambox and (other keys I suppose) other than TPS,Polsat,ABsatHotbird?
My plate is on the htobird sattelite.
mhku
Likes
20
TM Nano ~ sg2100
Midlands
#13
A bouquet is a "list" of channels. I use a "favourites" bouquet and add channels from the list of all channels to it.
Likes
Dreambox 500s
Greece
#14
I think you didnt get my question.Which channels can I see with dreambox,hotbird,and no cards,only with codes?
Likes
1,279
#15
Have a look at the Dreambox section, if you install one of the softcams and a key bundle, you can get most of what is curently available.
Moving this to the Dreambox section.
briosa
Likes
Sorry, but where can I find spartan keys? I`ve done a search for fookfiles, but I didn`t find Spartan Keys! I`ve a DB 7000s, I`ve problems witm my C-Panel, so I cann`t download keys to update, I use newcamd 6.01 and camd3. So, can you give a help?
john_graydon
Likes
Dublin....Ireland
#17
briosa said:
You can find Spartans keys in w_w.fookfiles.com under spartan in the list. You will have to register to get into it.
If you cant get into it you will have to get the keys off another key site.
What image are you using ??
