hello
i have got Sky installed at my home. wana install Dreambox satellite reciever instead but not sure which modelis suitable?
also is this installation straight away procedure or i would need some installation guys?
thanks
Virtually any of the DB's will work. Some are better supported than others.
Be aware a DB is NOT a receiver for beginners to the hobby - theres a horribly steep learning curve associated with any of them and you wont be taking it out of the box and be running it at anywhere near its full capabilities.
Why do you want a DB instead of a perfectly functional sky digibox?
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
