dual LNB, one dish, one Diseqc motor
tkalfaoglu
I have two dreambox receivers: a 500 and a 7000.
Turkey
Hi there. I have a dual LNB mounted on a diseqc motor..
Two receivers, one's antenna cable goes thru the diseqc motor, the other's wire just goes straight from the LNB to the receiver.
I'm having trouble finding the correct LOF/L LOF/H and threshold frequencies on the receiver that does NOT have the diseqc motor.
I'm trying to tune it to Eutelsat 7.0E, but it's not finding any frequencies..
Many thanks for any assistance..
-tk
Hello!
what is the type of your receiver?
when your modell,does not support the diseqec protikoll,and you cant select the entry in the menu,its not posible to move your diseqec motor!
what motor do you use?
usals protokoll your stb must support!
Turok said:
Hello!
thank you Turok, please re-read my message. the sattelite without the motor is the troublesome one..
okay,i understand now:)
what receiver you using?
what lof value set in the receiver,that does not work?
when you use a signalsplitter cable,and switch off the power off your stb,that is connected with the diseqec motor,then it could happen,that the 2.connected receiver,gets no lnb signal,because,the lnb,get no power,during you swtich your receiver off,check also your swtich,or try another stb on the 2input,when you have a twin lnb,with separate cable,then this would be the best solution ,then you have no signal lost,when you have a direct connection one !
