Duolabs CAS2 problem
New2It
Dreambox 7020, HH120 Discq notor with Triax 1.1m
I have just bought a CAS2 programmer for programming the Matrix Reloaded CAM.
Dowloaded the software from Duolabs.com but it seems to think that the CAS2 is a Dynamite and will only allow cards to be programmed.
Anybody had similar or know of any fixes?
Did you download and install the drivers as well as Cas studio?
Are you using the new 5.2.1 version?. If you are install the drivers in the driver folder first, unplug the interface and now install the software. Plug the interface back in and start the program. It start up correctly and make 2 "bong" sounds.
I also bought a cas2 and I have problems to comunicate with an arnion 6410 ucci,
I don't know if I need to use a "slow down printboard" and what I have to programm into the receiver first to put Mrev in the embedded cam (now original).
can somebody help me?
