Easiest installation for Sama tv
Dia M2030
Yahsat
Denmark
Hello guys
I would like to receive this channel (Sama TV) her in Denmark.
I googled it, I can see that I can I recesved it on:
Sama TV
3,1° E
Eutelsat 3D
11480 H
2963 3/4
Does anyone have any idea of, it is possible to receive a signal from this satallite, her in Denmark.
Footprints suggest that it should be a pretty simple affair - signals are strong in Denmark.
Actually, it's on 11468 H 2963: Either you've written it down incorrectly or it has moved since whatever Google item you saw was published.
As Captain Jack says, an easy catch: You are on the 49dBW contour so a 60cm dish should suffice.
Massive signal here in Northern UK!
I am viewing it now and my information is correct.
Okay thank you guys, I hope that I can find the satallie on my (satlink 6906).
I dont know if it exist!
Unfortunately I can not find this position on the satlink 6906.
I can only find this one eutelsat w3a, is it the same position.
Guys any one can help please.
Should be easy to find 3.1E without a meter anyway.
