EDISION PRIMO IP S2 H.265 HEVC MULTISTREAM
LeBelge
2x Triax TD 110, 2x Edision OS Mio 4K (plus), Edision OS Mini 4K, Edision OS Nino Pro
Belguim
Stevenvc19
3x Edision Primo S2:
30W
5W
0.8W
4.3E
9E
13E
19.2E
28.2E
Willebroek Belgium
Got the Spanish TDT channels on 30°W (Abertis) working on this tonight with the newest unofficial firmware.
They’re a bit of a faff - I had to add the “information” to THCAM (not OSCAM)’s list on the softcam menu on the receiver manually. Then you have to scan each transponder (12631, 12548, 12671 etc) one at a time with a reboot in between scanning each one. It finds all the channels that way - if you don’t reboot between each scan it won’t find any more channels after the first transponder.
Once they’re all on there though they work very well! Seamlessly integrated with the channel list and very snappy zapping!View attachment 120378
I can't seem to find all the "information" I need. When I search for channels, only some channels show. I can't find Cuatro or telecinco...
Maybe someone can help in some sort of way?
EnoSat
enosat.euweb.cz
Slovakia
must use right BISS key for scan
Mod. Note
This might be a suitable point at which to remind Members that Keys can neither be solicited nor offered here :)
LeBelge
Belguim
campag5242
Dishes: TD110, TD88
Receivers: SF4008, SX88, Samsung TV
NW UK
The Octagon SX88 behaved like that with FW1.04.70 - tuner/scanning death on 30W/Abertis & others - but was soon fixed at the next firmware release, such that a simple blindscan would pull in Abertis channels without the reboot faff between transponder scans.
Have updates for the Edision flavour of this csky cpu / gxapi box stopped? Latest update available online is 28/07/2018, PRIMO V1.04.62, while the SX88 has continued to receive updates to current 1.04.75...
Stevenvc19
30W
5W
0.8W
4.3E
9E
13E
19.2E
28.2E
Willebroek Belgium
today I scanned transponder 11344 V 27500 on the Astra 2 sat. To find Movies4men and Movies4men +1
The Primo only finds Movies4men. Not the +1 version!
Has anyone the same problem?
Movies4Men is on 11344 H 27500
Movies4Men +1 is on 11344 V 27500
FlySat Astra 2E/2F/2G @ 28.2° East
Please note that the Primo & SX88+ do no overwrite a new TV channel after a change has occurred so you have to remove the previous channel & re-scan the transponder,
Alternatively you can delete the transponder the either add it again manually or perform a Blind Scan,
The channel is probably in your data base but with the previous TV channel id.
Stevenvc19
30W
5W
0.8W
4.3E
9E
13E
19.2E
28.2E
Willebroek Belgium
Now I see... the difference in polarization... I didn’t notice that! Thank you so much!
RustySpoons
Sleepy Hollow
50E - 30W
2x CM 1.2m Polar Mount/Jack
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
I've just fired up the Edison for the first time (been busy with U3A and Tax Returns stuff for a few days), and updated the f/w after the prompt but not yet the channel lists - so I only have Hotbird and Astra 1 ATM, with the Rx driving the TD110 via USALS.
What "flabbergasts" me so far is omission of a direct "Sat" selection button on the R/C, and thus the clunky and long-winded method for changing satellites: press "OK", "Info" and then "Satellite" before you get the list of satellites from which you can select the one you want - or am I missing something "obvious"??
I know yours has gone. But for others press OK, thrn press Help a few times and then you get a list that you can select what Satellite you want. It widens the TV list and will stay in this view. So next time you just press OK and scroll to Satellite on the left ;)
hello my brother you can send the list of abertis channels thanks
Please stop asking for help with the Albertis channels or we will close / remove this thread as well.
galway
motorised and mutli sat
IRELAND
The multistream channels from 11491 & 11496 work fine with my Edision Primo.
You need to do the following:
Menu-> Instalation-> Factory default
after that you can install the latest .62 firmware and all will be fine.
Did you get those channels working Steve? I just got this box and no luck so far
popolon
south west of Finland
Teleste 5m,invacom quad (28.2E), invacom quattro (26.0E). Triax multiswitch (1in, 8 out)
-TT 1600 PCI. Prof 3701 PCI.
-DR HD F15
-Ariva ferguson A120
Aerial 3m dish (7W-28.5E) + motor+ invacom quad.
-Ariva ferguson A220.
Finland
Is this receiver firmware release notes (during 2018) lying about 27.5w support?
I've not got it to work.
Sufrer
Hisasat 30w
España
[QUOTE = "Adam792, post: 1060797, miembro: 330868"]
Consiguió que los canales de TDT en español en 30 ° W (Abertis) trabajaran en esto esta noche con el firmware no oficial más nuevo.
Son un poco faff: tuve que agregar la "información" a la lista de THCAM (no de OSCAM) en el menú de softcam en el receptor de forma manual. Luego, debe escanear cada transpondedor (12631, 12548, 12671, etc.) uno a la vez con un reinicio entre cada escaneo. Encuentra todos los canales de esa manera: si no reinicia entre cada exploración, no encontrará más canales después del primer transpondedor.
Una vez que todos están allí, aunque funcionan muy bien! Perfectamente integrado con la lista de canales y zapping muy rápido!View attachment 120378
[/CITAR]
Hola como se hace para ver la tdt hispasat con edision primo?
Sufrer
Hisasat 30w
España
[QUOTE = "galway, post: 1068524, miembro: 411165"]
¿Conseguiste esos canales trabajando Steve? Acabo de recibir esta caja y sin suerte hasta ahora
[/ CITAR]
[/ CITAR]
Hola alguien
Sufrer
Hisasat 30w
España
Hola alguien sabe como puedo ver tdt hispasat con edision primo ip2v
Sufrer
Hisasat 30w
España
[QUOTE = "Sufrer, post: 1069134, miembro: 413509"]
[/ CITAR]
[/ CITAR]
Hola alguien
[/CITAR]
[QUOTE = "LeBelge, post: 1060524, miembro: 404768"]
SCART fue muy útil hoy en el jardín.
La vieja tecnología de tubo de rayos catódicos (CRT) es mejor que la televisión LCD para un uso superior.
[/CITAR]
Como puedo ver tdt edision primo ip2? Podeis ayudar gracias
