Edit Default Transponder On Sky Digibox
Likes
tm-1000d,samsung9500,openbox-x, 1m - Amos+Sirius+Hotbird, 85cm - Express Am22
uk
#1
Hi. Does anyone know if there any way to edit preinstalled transponders on sky digibox ???? is there any tricks as "hiden menu" or etc ???
Thanx if U can help ;)
Likes
1,279
#2
You can change the default transponder, but if you are in the UK, there is really no point. You can add non EPG channels through the add channels menu, but there isn't much to add on Astra 28.2 East, you are also limited to two symbol rates when using it for other satellites.
Likes
uk
#3
I mean any way to edit preinstalled transponders
as i added another dish (Hotbird -with manual input switch ) but complicate to operate in "Other channels"
Likes
8,221
Skybox F3
Add Channels using Service 4, 4. Then watch the channel using services 6.
You can ONLY watch channels using symbol rates of 22000 and 27500. Also, the absolute maximum number of channels you can add is 50, but you need to keep it down to 20 or so or the box keeps deleting the added stuff!
If you want to play properly. buy a cheap fta digital receiver!
Likes
8,221
Skybox F3
me-68 why are you trying to do this with a sky digibox?? Ive just noticed your profile says you have 2 or 3 decent boxes including a Technomate TM1000 Get a disecq switch and you can switch away automatically.
Likes
uk
#7
It's for my daugther room. I dont watching Sky at all. But she does. I've got 2 dishes for 4 sat. ( Sirius,Hotbird,Amos & Express22am ) its all russian channels in uk ( about 50 )
But I know a lot of russian( or similar) people, who can't afford to buy a new reciever - they are using Sky digiboxes - as it cost around 10£ on market ( as second hand ).
Thats why Im interesting to find easy way to operate digibox with a different satellite. :confused
Likes
1,279
#8
Unfortunately there is no easy way.
Likes
uk
#9
Powerful reciever - but missing good soft probably for many years it hasn't been changed
THEY could enable edition channel list at :( list
Likes
3,067
#10
The software is regularly updated regularly by $ly but only to make themselves money.
If $lywere to make it easier for people to tune into other satellites then they wouldn't be watching $ly, would they?
