Help Required Elevation Angle VS Prime Focus and Offset Dishes
al_madhi
Riyadh - Saudi Arabia
How to determined the Elevation Angle for the Offset dish
Is this formula is correct below :-
The elevation angle for Offset dish = The elevation angle of Prime focus dish - offset angle of offset dish
Example:- The offset angle of offset dish = 22.36 deg. fixed angle from the dish factory
The elevation angle of the prime focus dish = 61.21 deg.
Then the elevation angle of the offset dish = 61.21 - 22,36 = 40.85 deg.
If tis not correct Ple
Is it motorised or fixed? try dishpointer.com it will give you the elevation for your location
