rsm42
- May 7, 2012
- Age
- 52
- Vu+ Duo - Novice
- Wales
I'm having issues with my EPG updating on my Vu + Duo box running the Vix
image v2.4. I'm connected to the Astra28.2 satellite.
Basically I've noted that the EPG stopped updating and only goes up to Sun at 17:00.
Do the updates come via the internet or via the satellite system ? Here's a summary of my current settings. Can anyone suggest the correct settings to use ?
System > EPG >
Location = media/hdd
Auto refresh = No
Auto save = Yes (24 hours)
CROSS EPG settings > Configure
Enable CSV import - Yes
Force epg reload on boot download - Yes
Scheduled download - Each hour (standby)
Show plug in - Yes
Show extension - Yes
The current Open TV providers enabled are :
SkyUK Open TV (Astra2 on 28.2)
SkyUK Open TV (Astra2 on 28.4)
I note when I download the second option 28.4, once the files are downloaded I often get a message "Service unavailable - Please check tuner config".
A bit of a longshot but I've noted the HDD is set to go to standby after 5 mins.
Could this be the issue ?
Thanks,
System > EPG >
Auto refresh = No
Show plug in - Yes
Thanks,
