Eutelsat W3 7e HELP
jayko
XXX
DM500+, DM800, CubeRevo HD, Sky UK HD x2, Viasat.
U.K
I am at work and would like to know if anybody in europe can lock this tp.
Satellite is 7e
12562 H 30000 3/4
No chance -its on the Southern Africa spot beam. And is scrambled in Videoguard anyway :D
Encryption not a problem for me. Just the beam.
Hi
This package also on 9E 11898 H 18613 3/4 Wde European Beam
Regards
Even if you are in a c/s ring - which Im sure you are from your commenst as HD1080 over on DS ;) you still need a card for it in there. Try the 9E version anyway.
I can get it here. help!!!!!!!!!!!!
He is in a card share ring.
DO NOT ask for or offer c/s'ing in this forum - you would get banned for that!
The transponder 12562 H 30000 3/4 is in Eutelsat W3A (not W3). Thanks.
Yes I know (W3 is now renamed W6 and is at 21.5E) :D
The same advice still stands.
