bureaucrazy
- Feb 16, 2012
- Age
- 55
- planning future installation of satellite TV
- east of england
I plan to have a dish with 2 quattrolnbs half way up the side of my house. There will be 8 cables in total. The cables will need to run about 2 or 3 meters up the wall into the loft. What is the best way to do this?
So far my options are:
A: use cable clips nailed into mortar for every cable individually
B: attach a gavanised cable tray to the wall with spacers/bracket underneath so that there is room to pull cable ties through the holes to secure each cable
C: use flexible conduit/tube and drill and screw brackets for this up the wall
D: use special 17mm thich 4lnb cable which is like 4 coax cables inside one sheath and clip to wall with pipe clips.
Thanks for any suggestions
