External CI+ and special CAM supporting SKY DE / SKY IT
Fringe_Sat
240CM Aluminum Prime Focus fixed Dish 19.2E
Inverto Black Ultra C120 Flange Twin LNB
Inverto Black Ultra 3208 Twin LNB
Octagon SF8008 Twin V1
Cairo, Egypt
Hi Guys,
My Receiver doesn't have a CI+ slot, I need an External CI+ interface and special CAM supporting SKY DE / SKY IT.
I also need to know how to buy these subscriptions from abroad.
Ive not seen any external cam arrangements for these cams so what you want may not be available.
Plenty of resellers will happily sell you Sky Gemany or Sky Italia, but they are VERY expensive - one reseller Ive happend to find you will be paying over Eu2000 a YEAR for Sky Germany alone
I have a high school friend in germany, even if he gets me the box and card I still want to use my Enigma2 SF8008 STB
I have several receivers and among them a SF8008 and two VU+ DUO 4K SE.
I think the VU+ is the better one and it has two CI+ slots.
Isn't it easier to use a VU+ receiver if you want to use a CAM and card? The DUO 4K SE seems to be hard to get at the moment but the UNO 4K SE is available and has one CI+ slot.
Yes but its low on stock and over priced, they sell it here for above 600 USD [VU+ DUO 4K SE]
my used Octagon SF80008 V1 for 100 USD is the best bang for the buck.
I need to get an external CI+ interface with USB connection and opensource driver compatible with enigma, then I need to get the proper CAM, then get the card and box, then configure the OSCAM to read the card
I don't know which hardware to get and I don't know how to setup OSCAM for this.
You are looking for somehting similar to Hauppauge Win-TV CI USB , i use mine on a mac with eyetv. i know that it is also functional with some tinkering on linux. WinTV-CI / Cinergy-USB-CI und ddci2 - VDR Portal
It works on windows too
i have a VU+ DUO 4K SE as an e2 box but have never tried on it.
Thanks I will check it, do you know a CAM that can ready Sky Cards, A sky subscription should be enough, All Sky Packages support English
i have no idea
