bignick
- Feb 13, 2005
- Age
- 56
- Back in the UK and missing Cyprus!!!
- Aylesbury
Hi guys
Myself and manicop went back out to this dish recently to re-finetune it as the owner rekoned he lost some channels at about 2300L. We reset it using Simons petal removal idea...:-thumb1.... worked a treat!! It helps that we are starting to understand how to get the best out of the satlook now. I'll phone the guy back in a day or two just to make sure its gone ok but we both felt there was a massive improvement and it was ssssooo much easier with the petal out of the way.
Cheers
Nick
Cheers
Nick
simonskyman said:It seems you did a good job if it works all night.Well done guys.What about 8-10am?
Does ITV Yorkshire(10.891H) work after 7 pm?And ABC1 (channel 281).
I just started using the satlook recently(because i lost my roversat) and i cant get the "4th light" on or s/n readings,bloody annoying so i rely on the spectrum and span reading.
One other tip is to take off the bottom petal so you can get closer to the dish and adjust lnb for final readings without disturbing the dish,then carefully put petal back.
As for not been in line,I had that problem on a couple of dishes but not a big deal as long as the final shape is not warped,you can tell by looking at the dish from a side ans bottom view.do you have the old beige dish and new grey petals?The grey dishes have a slightly different edge that fits better to the petals.
