FAO: Nobbly and bin 2 hex experts
Shahid
Sony KLV26HG2 LCD TV, Humax HD-CI 2000 on a Fixed Sky/Astra/Hotbird.
Cerebro Card. Infinity USB Phonix. Dragon Cam v4.1 w/Firecrypt & Loader Card.
London UK
Quote from Nobbly " Overview of process
The goal is to get a key file into the EEPROM, and a software file (including key-decryption algorithms) into the PIC.
The software file is usually a hexadecimal (xxx.HEX) file.
The key file is usually a binary (xxx.BIN) file.
A loader (or "boot") file may also be needed in order to pass the key file through the PIC and into the EEPROM. The loader will typically be a HEX file.
Some programming utilities will demand that the file for the EEPROM is indeed a BIN file, and the others are HEX. But if the downloaded files are not in those formats, don't worry: there are utilities available for converting from one to the other."
Nobbly where can I find the bin to hex converter software?
Please help.
2old4this
Honorary Admin
Cloud Cuckoo Land
actually, I believe you're quoting me there.
In any event, find attached such a tool.
Just drag/drop the hex or bin file onto this exe, and it generates the reverse format in the same directory as the original.
2old
Shahid
London UK
