Favourites?
RedDevil_UK
Retired Mod
Dreambox 7000S, VU+ Solo2, 1.1m Dish, Moteck SG-2100A DISEQC Motor
Rochdale
well i have finally got some channels, and some good ones too :)
but i was going to make a favourites listing... i see the option, but how the hell do you do it?
its gonna be something so damn easy... i just know it :P
PS.
Just one other question, alot of channels still cant be decrypted, are some cams and keys better for sport, films etc
or do you just pick one and stick with it?
i was just wondering if you guys change them each day, depending on your choice of viewing that day
dont matter about the favourites... ive sussed it :)
still wouldnt mind knowing about the cams and keys though?
RedDevil_UK said:
Still wouldnt mind knowing about the cams and keys though?
As far as I am aware newcamd version 5.24 will decode most of the channels (with k*ys).
Mary's K*ys seem to be the latest but again not sure where they live!
If - Dreamcrypt, Radeqast etc can do something different can someone explain please?
Well, I am using scam 28.8.04 and that seems to open up everything I need...
Especially TPS Star where I wil watch the game later this afternoon O-Ha
to be honest i have 6 soft cams installed, but does it use them all auto?
or do you have to choose? it seems to use the default cam all the time
if you can change it for one channel (say TPS star) how do you do it?
What image are you using?
Try the blue key while in a channel - in some images you can specify which soft CAM to use for each channel.
The latest Newcamd should work for most inc. TPS
Yes, newcamd 5.23/24 does just about everything.
Radegast for example does Multivision 1-8 and some of the other bundle members, but doesnt/didnt do TPS cinema channels.
So far, I set Newcamd to be default.
I have then worked thru channels I can't make clear and tried the other s-cams. I did not find a s-cam that cleared a channel that Newcamd could not. Here's a challenge to y'all. Find one.
Mary's bundle resides on
http://*****.******.***.au/hydra/keys/mary.tar.gz
and maybe other places
(Does anyone really need that url or can they rely on flash image to get them?)
Now this is one of life's mysteries; why the stuff we need is down under.
I know they use DBs in Oz, but didnt know they needed keys for euro channels. I hope there is a mutual deal. Eu posts their keys, au posts Eu.
