fibo motor parts .
mikie8
Humax HDCI-2000
Diablo wifi
dgstation 200s+ modded to 64Mb
Gibbertini 1.2M Channel Master feedhorn Inverto white
Fibo 90Cm fibo motor inverto white
85cm generic 2600 TM , black ultra
Superjack dp6600
Pace Mss-500
dagenham
i need a few fibo motor parts . the h22b1 , brass gear and motor itself . if anyone has some parts or a non working motor that has some of the parts i need i would gladly welcome your responce .
i really want my new (to me) fibo up and running . i want to keep the original look so please no need to sujest alternatives .
thanks mikie
Rick
Retired Mod
Fibo 1.2m HH, Wavefield T90. AzBox HD Premium, Vu+ Duo
Blackburn, Lancs
You could try getting in touch with gunnar over on fibo owners. He has quite a few Fibo parts for sale and might be able to help you out.
mikie8
Humax HDCI-2000
Diablo wifi
Superjack dp6600
Pace Mss-500
dagenham
thanks for the reply rick .
ive put a thread on fibo owners but not much response .
im going to buy a complete replacement anyway but i would like to repair the one i have as a spare .
btw . im going to try your ( rick ) 5v mod ive seen on this site . i have a dp6600 to try it on .
Rick
Retired Mod
Blackburn, Lancs
You could try dropping him a PM. I know he is traveling about at the momen't and I'm not expecting to hear from him about a motor I've ordered till next week.
It's a good mod for a positioner. Saves buying a new one, or getting hold of something like an old echostar to use as a positioner. Make sure the 7805 regulator has a heatsink, otherwise they can get too hot and burn out.
mikie8
Humax HDCI-2000
Diablo wifi
Superjack dp6600
Pace Mss-500
dagenham
great advice rick , i bought a motor off gunnar and its working great .
but i did the 5v mod and the cap on the output burnt out . i have to input to a 21v line , will a heatsink stop the cap burning out ?
Rick
Retired Mod
Blackburn, Lancs
Could just be a bad cap. It's the regulator that gets hot and needs a heatsink, on mine atleast. I would replace the cap, and double check your solder joints, a bad joint can cause them to burn out, and it's easy done.
mikie8
Humax HDCI-2000
Diablo wifi
Superjack dp6600
Pace Mss-500
dagenham
thanks for responding rick .
i soldered the cap in backwards , dont ask .
trying to rush as ive now finally got everything to setup my fibo for good , although i will be upgrading the lnb in the new year with qdf031 unless you know of a lnb that works better on a 90cm fibo .
ive got a pace mss500 to use for now and i will replace the cap and get a heatsink before i try the dp6600 again .
Rick
Retired Mod
Blackburn, Lancs
