redout
- 1M Dish with Motek 2100,
DM 500 & DM 800HD, Vu+ Duo,
Digital+, Sky+, TDT, Saorview
- Dublin
On the D800 in the positioner setup menu (not the one were you enter lat and long) but the one were you can set limits and move the dish east or west.
If I move the dish through this method and find a satellite and then click the store position button will I have this satellite saved on my sat list to use when I want or saved in the positioner setup menu.
Basically I just want to make sure by finding a satellite this way and hitting store position that it wont mess up my USALS lat and long. Getting confused because of the menu name "Positioner setup" being the same as the one you enter lat and long for USALS.
Thx
Thx
