firmware
Rolf
I can't seem to get the dragonload to connect i have a Elvis programmer,
any idea's, i have checked all the settings are correct, Multiprog connected and in Phoenix mode.
Hi
I came across this post from TJ regarding Elvis Programmers:
ELVIS INSTRUCTIONS BY TJ1965
for the older serial "elvis" and definitely for the yellow 3.6 usb "elvis"
using multiprog v1.80 or later !!!
To program the picbased card, one needs to have the USB version of the programmer, the old serial version can't handle this card.
Go to the Dragonloader tab.
Give the project a name. Load the *.dra file, and select Dragonloader as card type. Then just press program, sit back and wait, since it takes a while.
This way of loading works for Fun7 based cards to, but it is much slower.
best regards
TJ
ps:- please note that the serial version of an elvis cannot program the pic version of the card because it does not have the 6.00 mhz phoenix mode required for this task
both of them ( serial and usb ) can program a funcard 7 ( prussian 5 )
Can you please provide more information on your programmer.
Best wishes
Mickha
Hi.
I have the serial type Elvis, so what are my options? can i in anyway use this proggy to program the Dragon loader.
Richie
Hi richardp,
you can program the Dragon with a Fun Card 7, which is available for around £10, otherwise you require a newer programmer or even a CAS3. The cheapest option is to get a Fun Card 7, maybe if you contact your Dragon Cam supplier, and explain the problem, they will exchange your card for you.
Best wishes
Mickha
For completeness two useful links:
dragonsupport
http://www.ucassupport.nl/dragonsupport/english/index1.htm
ucassupport
http://www.ucassupport.nl/english/index1.htm
