first run on new motor
Sir Bronking
Sir Bronking
Likes
medion
pentium4 3.2ghz
progdvb
skystar2 rev2.3
1mtr dish & jaeger 99G 36v motor, with a superjack DP-6600. dvb-t aswell,in the process of setting up
cheshire,algeria
#1
hi guy's,
having set motor up at 1w, on my first sweep results are below:
28.2E, 10714H 37% 36%
19.2E, 11720H 38% 39%
16E, 11449H 62% 41%
13E, 11131V 40% 39%
7E, 11492V 38% 30%
5E, 12073H 73% 65%
1W 11421H 62%
4W 10743H 48% 56%
5W 11591H 91% 92%
8W 11556H 73% 74%
12.5w nothing (cannot find) 64%
15W 11150V 55% Cannot find
18W nothing (cannot find) cannot find
22W nothing (cannot find) cannot find
30W nothing (cannot find) cannot find
now before i go tweaking about, any sug's for which way i tweak and why, also any more sat's (with strong transponders) i should be looking for to give me a clearer picture as to what's wrong with my arc
blue second run
john_graydon
john_graydon
Likes
Dublin....Ireland
#2
Where is the rest, ie 36e,39e,42e,45e,4w,5w,8w,12.5w,18w,22w,27w,30w ????????????? Can you not get these.
Lancelot
Lancelot
Retired Mod
Likes
SS1.
36v H to H 62E - 61.5W
South central
#3
43W,45W,58W,61W O-Ha
Seriously though, if one side of the arc is missing (as it looks) then have you checked that complex extension you put on from the O/P shaft?. It looks like it has the potential to put your dish off square slightly (almost like an S bend effect) if you are not very careful when tightening it up.
Oh - have you got the line amp in ??
Here we are....
http://www.satellites.co.uk/php-bin/forum/showthread.php?t=28972&highlight=strongest
L.:)
Sir Bronking
Sir Bronking
Likes
medion
pentium4 3.2ghz
progdvb
skystar2 rev2.3
cheshire,algeria
#4
sorry guy's got called away,
anyway look at piccy, it might give better indication,
Sir Bronking
Sir Bronking
Likes
medion
pentium4 3.2ghz
progdvb
skystar2 rev2.3
cheshire,algeria
#5
checked everything for verticals, second run :(
Likes
1,291
#6
Looks like the motor inclination is wrong.
Sir Bronking
Sir Bronking
Likes
medion
pentium4 3.2ghz
progdvb
skystar2 rev2.3
cheshire,algeria
#7
just going for a brew,
how is the motor inclination wrong when it's set accrding to manual,
unless the manuals wrong:-doh!
i'm seriouly thinking about setting up as moteck angle, and working out declination of dish from that,
see you in half hour
Likes
1,291
#8
Well either that or your arc is skewed to one side or the other, you need to locate 28.2E and then try tilting the dish up and down to see which one improves it, then try the other side and see which one gains an improvement.
T_G
T_G
The Consumate Dreamer
Likes
215
1 GigaBlue Quad plus, 1 Dreambox 5620, MOTECK SG2100A DISEqC Motor, 120 cm noname offset dish, Humax 95 cm offset dish and a few UK digiboxes.
Somewhere where the Sauer is Kraut and the Wurst is Brat
#9
Don't want to repeat myself or contradict any advice given to you by others, but since I have my dish working from 51w to 53 east it seems to work:
If you are in the UK, use 1 West. Put in your long/lat in the disecq settings and choose BBC world for station. Motor will move to a position. Set the motor angle according to manufacturer. Set the dish angle by moving it slowly up and down / sideways with someone helping you if you cannot see the TV, don"t use the degree numbers on the dish.
If the pole is straight you will then have all the sats. This is how i done it, never used any sat meters or anything.
Sir Bronking
Sir Bronking
Likes
medion
pentium4 3.2ghz
progdvb
skystar2 rev2.3
cheshire,algeria
#10
T_G, you have this dish (dish isn't the problem) and motor ?
johnsattuk
johnsattuk
Likes
2
Topfield 5800 Echostar3000,DB7000, Relook 400S, Humax HDC2000, 55cm Fibo Gregorian dish with waveguide and Motek 2100 mod, 90cm Fibo Gregorian dish, 120cm Fibo Gregorian dish on a 1224 motor with waveguide
West Mids, UK
#11
I dont know about your particular mount, but I think that the markings that are stamped on brackets generally, may not be as acurate as we might think. With manufacturing tolerances etc. I think we would be lucky to end up within +/- 1deg of the desired angle.
Topper
Topper
Amo Amas Amant Admin
Likes
3,346
IDD CI24 ECONO MM Penta 1.20 Galaxy II
1.2Mtr Polar MTG yes it has been on the arc for 25 years and is now fixed on 13 East using two pairs of rusty molegrips. Unlike me they never groan but always perform.
Blackburn, Lancashire
#12
I couldn't agree more John, in fact I think you would be lucky if they were that close + - Diana Ross would be more like it or or should that 3 degrees?
T_G
T_G
Likes
215
#13
I got an SG1200 and the two dishes I put on had no markings on whatsoever. This is why I put the motor angle in, and then found the dish angle with a satellite. I think that putting in both values and then hoping it will be spot on is too much for this motor and dishes. I find it extremely easy to find satellites with the dreambox, all you need to do is know the general direction of the sat (always use neighbours dishes for reference, or use a compass). If you get the motor one right you will be ok.
What is the situation now with your dish?
Sir Bronking
Sir Bronking
Likes
medion
pentium4 3.2ghz
progdvb
skystar2 rev2.3
cheshire,algeria
#14
just a quick update, (i'm off to play darts)
the markings on the motor are a bag of sh*te (as yeshi would say)
i have now found 30w so having got 28.2e, i'm edging towards a full arc, getting ready for fine adjustments (tommorrow)
incidently i was looking at toppers set (brilliant wiper motor ), but it struck that he mustn't have any skew(is the the word) on his dish at all, (which of course has got me thinking) after i've got set up right, i might get straight peice of pole, put it on motor instead of bent one realigne dish and motor and see wheather it makes that much diff
johnsattuk
johnsattuk
Likes
2
West Mids, UK
#15
I am sure that Topper will get the same skew on his dish as any other correctly set up system.
The skew comes from the turning axis of the system being at an inclined angle. In systems that use the motor as the pivot the motor is set at an angle, Toppers set up has pivot axis, which although seperate from his drive motor, is also set at an inclined angle.
Bent shafts or straight shafts do not have any effect on skew, there is only one axis and everything fastened to the motor shaft moves on that axis.
Sir Bronking
Sir Bronking
Likes
medion
pentium4 3.2ghz
progdvb
skystar2 rev2.3
cheshire,algeria
#16
update third run,(sorry late, her indoors job's to do)
28.2E, 10714H 37% 36% 54%
19.2E, 11720H 38% 39% 50%
16E, 11449H 62% 41% 73%
13E, 11131V 40% 39% 64%
7E, 11492V 38% 30% 56%
5E, 12073H 73% 65% 73%
1W 11421H 62% 78%
4W 10743H 48% 56% cannot find ?
5W 11591H 91% 92% 92%
8W 11556H 73% 74% 63%
12.5w nothing (cannot find) 64% 64%
15W 11150V 55% Cannot find 56%
18W nothing (cannot find) cannot find had it, lost it ?
22W nothing (cannot find) cannot find cannot find?
30W nothing (cannot find) cannot find 70%
blue second run
red third run
Lancelot
Lancelot
Retired Mod
Likes
SS1.
South central
#17
Can you get around to 39E or 45W to give a picture of the edges I wonder??
L.:)
Sir Bronking
Sir Bronking
Likes
medion
pentium4 3.2ghz
progdvb
skystar2 rev2.3
cheshire,algeria
#18
L.:)
i'll edge along then, would 45w be the next sat i could get with 1mtr dish (surely something before that) strongest transponder?
ps also looking for feeds for city v wigan fa cup
Lancelot
Lancelot
Retired Mod
Likes
SS1.
South central
#19
12650H 30800 on 43W will be very strong.
L.:)
Sir Bronking
Sir Bronking
Likes
medion
pentium4 3.2ghz
progdvb
skystar2 rev2.3
cheshire,algeria
#20
:( 43w cannot find,
i'm using fast satfinder program with the vbox as a stand alone positioner, is it worth running lnb into vbox then out into ss2 just while i finish tweaking (ie would it help me)
