first strike sat meter help
kery
technomate 6900 hd 8x1 disq 28e 19e 16e 13e 30w 1w 7e diablo cam 2.3 and many more
ireland
Hi hope some one has one of these i just got one and need a bit of help setting it up not sure is it me or a bug in it have you got one thats working ok on all sats thanks
Need more information, the model number and the type of 'bug'.
Ok thanks its First strike meter FS1 s/n 0909k00028 brand new dont see a model number not sure is it a bug or me set it up got it working on 19e and 13e no problem so went for 28e 1w and 16e and 30w to name a few but will not find them so brought out tv and and sat box say on 28e and have them on box so put meter on to lnb no sat found put freq in meter manualy as the same on the box but still no joy hope you have one and can help also i thought with this meter when you connect meter to box it will charge and when its connected you would have a signal on box too but there is no signal when i do this on box tried to explain the best i can to you thanks
As you have the internet, are you sure you are putting in the correct frequencies for the other satellites ?
Is the meter readout four, or five digits ?
How big is the dish you are conecting it to, and what type of motor ?
Are you adjusting the elevation of the dish when moving off the two other satellites?
Yes i am beam to the satellite 100% as i have them on my technomate, but not getting signal on meter direct to lnb but it will pick up 19e and 13e but no joy with the rest yes have freq done manual same as box to make sure just in case there list is out its strange do you have one of these meters and do you have any problems thanks
Ive got a feeling the motor might be stopping the 22kHz tone, or it may not be generated by the meter.
What motor i do not have one as said in the above post direct on to lnb its the meter thats not getting sat signal thanks any way
Are you saying that you cannot get the meter to show a signal on any satellites?
Do you have to toggle on the LNB voltage in the meter first?
PS. Please try and use some punctuation, your posts are very hard to read.
Ok here we what i am saying, it picks up 19e 13e no problems, its very strange it does not find 28e 16e and many more. The first thing you will say is i have wrong freq in meter, i would say the same myself so in put all freq my self and still no joy. Do not have anything only lnb and dish, as am doing it outside, but when i connect my sat box to it it has signal but nothing showing on meter on these. To me it sounds like sofware problem, i am on to first strike to see what they think, im at a lost thanks for your help.
Have added some punctuation to your post above.
16E may be a difficult catch with anything less than a 90cm dish and can be swamped by 13E and 19E, 28.2 East is substantially lower in the Sky, so you may have the dish too high when looking for that bird.
Pictures of the meter (one on a working satellite and one on a non working one) would be a good idea
Ok have it sorted now problem switching problem on meter is different setting on 19e and 13e and 1w and 16e and a few more working 100% now on all very happy with meter thanks to all who help me
Doesn't help anyone else who might have a similar problem though. What did you do, (or First strike suggest) to solve it ?
There is a 22khz setting on meter this switches the Lnbf Lo frequencies 22khz off chooses 09750 and on its 10600 so on 28.2e is off and 19e 13e is on
That selection is relevant to frequency not satellite, as there are both high and low band transponders on all of those satellites, it is dependent on the recognition frequencies you choose for each satellite.
sorry mate i sold mine long ago but i can say the best thing is that you can connect to lnb cable coming from receiver to get power,i couldn't find that in many other meters,answering your questions although didn't get it well,i say it's a very simple unit just pay attention to 18 and 12 because one is vertical the other horizantal
An up to date satellite database would of helped you out with your above problem which would of included all of the latest freqs & LNB settings etc.
Your meter would of come with the global database which is factory set and is more geared up for the USA and is not upto date with the Europe settings.
We have now done our very own custom UK & Europe database for these meters which you can now request from the First Strike official website subject to you having registered your meters serial number with them. Its includes all major satellites from 60e to 60w
Anyone purchasing a meter from us direct, now has the option of us pre loading this database for you at no extra cost so the meter is ready to go out of the box with all the latest freqs & settings for our region which will save you alot of time.
