fix magic cam with cas?
V
vakos
hi to everyone here
i use cas 2 to program my matrix cam
i tried to program a magic cam but something whent wrong
can someone hellp me to put back on my magic cam the dreamflash
for the moment when i put the cam in the receiver it says initializig
billystevo
billystevo
You might need to use a xilinx repair file , i think theres one on Allsat
G
gfcc1
theres also one on the forum i used it the other day and it worked a treat
N
nobann
erase all, use reparing xilinx(matrix.cas) file, then bin file(mr1170) if U are using MM. MRV2.20 is a lil bit heavy for an MM as I noticed
