fixed mount for philips gregorian 90cm?
Yes, Satmueller.de do them. Presumably its just the Ez/EL mount you are after.
i know this is an old thread but just bought a Fibo/Phillips dish that comes with the motor would like to remove the motor and fit a modern motor you are talking about a adapter bracket from _http://satmueller.de/englisch/produktframe.htm would you know what the bracket is called . thanks for any help
sorry its taken a while to reply would have liked to have helped as im also in warwickshire,its pole mount or fixed mount mate satmueller will no what you mean ,be warned very pricey,be better trying to get one of our skilled members to make you one
thanks for the reply got a mount from sat muller had to modify it so it was in the centre fitted a dark motor working well thanks anyway
