flashing
moosegoose
bog standard
80 cm dish hh motor teco tm1000 dreambox 7020
cas 3interface
dragon cam.promax tv explorer 2.
norwich
hi trying to flash new gemini image using the web interface . My set up is dreambox connected to wireless router with either net cable .Not sure if i am using the right interface .I typed my dreambox ip add on my browser and the dreambox interface was displayed .I can also control the dream box which when u have been trying for 2 days seems pretty cool .In the guide it says turn off power to dream box hold bottom channel button and turn power on and wait until stop appears .Tried this several times but nothing .It just boots up to channel i was last watching .After another long day i found the bottom channel button do not work .Ie i can not change channel down on the receiver .Will this affect what i am trying to do . ps the box is new and has the enigma image at present.l
You need to use DreamUP to flash an image.
p.s. And the . goes at the end of the sentence. Like this. Not like this .Makes it easier to read, as do a few carriage returns and Capital Letters.
will usb to serial 9-pin male do as i have no serial connection on my laptop.
Here is a simple guide on how to flash the 7020 using your web browser, IE can lock up sometimes but Firefox works fine.
You will need Microsoft Word or Word viewer to view this file.
thanks sonic 1 and mhku i flashed with gemini this morning using the null modem cable.i tried that way last night sonic but found that the lower channel button on my receiver is not working .It will not change channel no response .The channel up button works fine.I will email suppliers tomorrow to see if its faulty.
Try changing the batteries in the remote first- it's not the best remote in the world.
The remote works ok mhku its the lower channel button on the receiver that is not working.
Thanks will have a read as im thinking of buying dm7020
The advantage of flashing with web browser is the time that delays: less than 1 minute.
With dreamup (with null modem cable) delay about 30 minutes
Tested on my 7020
Yes, always try to flash using the browser :)
